convert png to gif in Labview
Hi all,
I am using Labview 8.6. In my application i want to convert a PNG File to GIF file. Is there any vi for converting PNG to GIF?
Thanks in Advance,
Vaira Muthu.
Message 1 of 8
(4,257 Views)
Hi Vaira,
The only way I know is to use "ImageMagick Batch Image Converter VI" that you can find here.
You will need to install the ImageMagick convert sotware on your computer first though.
I hope this helps
Epictetus
Antoine Chalons
Message 2 of 8
(4,251 Views)
Hi Titou,
Thanks for you reply.. But for the vi that you suggested, i need to install some packages. I dont want to do that custom installations. Is there any other options available in LabVIEW?
Vaira Muthu.
Message 3 of 8
(4,243 Views)
I don't think you can, at least not in LabVIEW 8.6 and earlier, I don't know about LV 2009, and if you want to suggest it for LabVIEW 2010 you can post here.
Sorry... Why is it a problem for you to install ImageMagick?
Epictetus
Antoine Chalons
Message 4 of 8
(4,227 Views)
Accepted by topic author Vairamuthu
If you only want to write the GIF file, there is a function (not in the palettes) that will write the contents of a LabVIEW image to GIF.
Look for LabVIEW 8.6\vi.lib\picture\gif.llb\Write GIF File.vi
Message 5 of 8
(4,211 Views)
Hi Phillip,
Thanks for you answer...
Message 6 of 8
(4,202 Views)
Hi Titou,
That is a third party software(i guess). So only. 🙂
If it comes with LabVIEW Development Software. Then whether it will be included in the Device Driver DVD? or i need to get any cd from NI. Because to use that vi(you suggested) it need some package to be installed. 😞
Vaira Muthu.
Message 7 of 8
(4,201 Views)
Good shot Phillip!
I didn't know about that :-o...
Epictetus
Antoine Chalons
Message 8 of 8
(4,172 Views)
