02-15-2010 10:24 AM
I have an appliction where on the front panel I need to display anywhere from 1 to 16 channels in a stacked waveform plot. for ease of viewing, I would like the entries in the plot legend to line up with their respective channels in the graphs, similar to the rather crude picture i'm attaching. The hangup in this is I need to be able to vary the number of charts displayed, 16 max, during runtime.
In my mind, one option is to go with subpanels and have a panel setup for each number of channels i wish to display. However, I think this would be easier if it were supported by the Waveform Chart itself. I'm open to any and all suggestions. Thanks!!!
02-15-2010 10:40 AM - edited 02-15-2010 10:45 AM
If your plot areas are that narrow you can resize the default plot legend text size to meet the size of one plot window. Like this:
The number of plot legend lines shown can be adjusted by using Create -> Property Node -> Legend -> Number of Rows.
Also you can select which plot will be visible/invisible in any given time by using Property Node -> Active Plot and Property Node -> Plot -> Visible combination.
02-15-2010 10:47 AM
