convert multiple length numerics to string for a table
Perhaps I am over complicating this, but the solution evades me.....
I have a mix of numeric types (lengths) that I want to display in a table together.
is there an easy method to do a "convert to string" on a 2d array that displays all differing lengths of numbers?
If I use Fractional convert on the array I end up with numbers all being the same length, see below.
eg. How I want it displayed: (note the varying lengths of numerics)
Applied Volts
Frequency
Duration
Range
0.018
50
5
0.04
0.1
50
5
0.4
0.45
50
5
1
1.8
1000
10
4
45
10000
10
100
Not how I want it: ( all at 3 dec places)
Applied Volts
Frequency
Duration
Range
0.018
50.000
5.000
0.040
0.100
50.000
5.000
0.400
0.450
50.000
5.000
1.000
1.800
1000.000
10.000
4.000
45.000
10000.000
10.000
100.000
(2,332 Views)
How do you define which cells have which formats? Is the numeric data in an array or does it come from multiple sources?
Lynn
(2,329 Views)
My routine reads in all those values in the table from a CSV file and converts them to numbers to control the instrumentation and perform calcs.
Just dawned on me that I could grab the raw string data as soon as I have read it from the CSV and push it straight to the table.
However, I am still curious if there is an easy way to represent varying length numerics in a table together. Ie I don't want set a length of 2, 4, or 6 etc, I just want the total number of digits shown in the table.
(2,317 Views)
Hi Adam,
it's all in the LabVIEW help: read about those different string formatting codes!
I would try something like "%#.6f" to get rid of trailing zeros…
(2,287 Views)
