convert hex string to number
this should be easy, but I can't seem to get it. I want to convert a hex number in string format such as 044A into a number that comes out on my calculator as 1410. The hex to number vi in the string pallete gives me a big fat 0.
 I hope the snippet helps.
Tay
(I hate Hex!) 😞
(4,067 Views)
Turn off 'Hex Display' on the string and try again.
(4,051 Views)
Accepted by topic author slipstick
Hex 044A is equal to decimal 1098 and if you have a string set to normal display and use the Hex String to Number function, you will get 1098 out.  Decimal 1410 is equal to hex 0582.
(4,050 Views)
