convert hex number to binary number array
I need to convert hex number into binary number array.
Can someone show me how?
For example,
num1 = 0xFA
I need to put into binary array,
         index 0 1 2 3 4 5 6 7
value (LSB)0 1 0 1 1 1 1 1(MSB)
Thank you.
(10,762 Views)
Hi horanyee,
   Use num to boolean array function which nis present in boolean pallette....
Srikrishna
(10,756 Views)
Additional info: if you actually want zeros and ones you can add a Boolean to 0,1 function.
(10,731 Views)
here you go ..
Guru
Guru (CLA)
(10,730 Views)
Guruthilak wrote:
here you go ..
Guru
There's a couple of issues with this solution:
  • It gives you a string array, and the OP asked for a binary number array, which I take to mean an array of zeros and ones.
  • It does not give you the full 8 bits, including the preceding zeros. This can be remedied by changing the format string to %08b.
  • A more compact way (albeit at the expense of a small coercion) to get your string array result is the following:
Message Edited by smercurio_fc on 12-21-2009 11:09 PM
(10,720 Views)
Accepted by horanyee
Guru,
You are generating a string array instead of a number array like the op asked for and the order of your array is reversed.
What srikrishnaNF and smercurio_fc are descibing is this simple code.
(10,719 Views)
