convert from version 5 to version 8.5
I am trying to convert a V5 vi to V8.5 vi. Need help. Thanks.
Rut
Message 1 of 13
(4,546 Views)
At LabVIEW 6 NI changed the report generation libraries.  The older calls passed a copy of the document between VIs.  The newer calls pass a reference to the document beween VIs.  If the program you're trying to convert uses report generation, you will have to rewrite / rewire those calls.  There are other changes of courxe, but the compiler deals with most of those, I think.
Message 2 of 13
(4,539 Views)
With 8.5, you cannot directly open 5.x VIs at all. You need to first convert to 6.x, 7.x, or 8.0/8.2. See the recent post here.
Message 3 of 13
(4,534 Views)
Thanks a lot. I think I have to write it on my own.
Rut.
Message 4 of 13
(4,499 Views)
Pls can anyone convert this vi to v8.5
Message 5 of 13
(4,292 Views)
Vi is here
Message 6 of 13
(4,290 Views)
Hi Veeru,
Hopefully this works.
Aashish M
CEO
TransferFi
www.transferfi.com
Message 7 of 13
(4,255 Views)
Thanks Aashish
Message 8 of 13
(4,246 Views)
I have an instrument driver that was written in version 5.0.  I need to convert to version 8.5.  If what I see is correct 8.2 should open and convert.
Message 9 of 13
(4,095 Views)
Here you go!!
Aashish M
CEO
TransferFi
www.transferfi.com
Message 10 of 13
(4,066 Views)
