07-20-2005 03:11 PM
Check the online help for more details. 🙂
@altenbach wrote:
(You seem to convert all decimal points to commas, thus you probably use a non-US OS (German?). If all your strings have decimal points instead of commas, you can just disable the local decimal point in "Fract/Exp String to Number" as shown. Your version actually does not work correctly on an US computer, because the commas are not recognized as decimal separator here.)
As an additional note, remember that you can programmatically switch between period decimal and comma decimal format, by using the following silent formatting codes:
%,; --> Comma decimal separator
%.; --> Period Decimal separator
%; --> System default sperator
04-24-2008 10:48 AM
04-24-2008 11:00 AM
Yes. Regional settings are a function of which user is logged in. Each user can have their own settings. For a new user who has never logged in before, Windows sets their settings to some default. I'm not sure how you can change the defaults that Windows uses.
I'm not clear on exactly what your problem is. Can you post an example of the code you are using? Is it comma or period that is being used in the string? What is the regional setting for the user logged in?
04-25-2008 01:17 AM
04-25-2008 01:33 AM
