I can't access to my ni pxi-5102 from max
Hello.
My system is a ni pxi 8106 RT with labview real time software embedded in a chassis pxi 1042.
I have put into 2 cards:
1) ni pxi-5102 digitizer
2) ni pxi-7831R FPGA
When I open Max everything looks ok, I have the system in my subnet and I see it and the cards installed.
I have also installed all the RT software on the target.
The problems are 2:
1)From max if I double click on the pxi5102 I can see only the information but I don't see channels(that should be 2). I tryed from data neighborhood to set an analog input but it says no supported device found.
2)When I try to open the visa test panel test says that the access to the remote machine is denied because of insufficient privilege.
Do I have incompatibility problems?
Did I missing some settings?
thanks a lot!!
Ciao
Mario
(3,093 Views)
Hello Mario,
if i understand you correctly you use your pxi system as a real time target.
You are not able to config a channel or task in MAX because the device pxi 5102  dosent work with the DAQmx dirver.
And in the data neighborhood you can only select DAQmx and not the scope driver.
For the point 2 i need more info (error code).
Maybe you will post a print screen and describe the procedure.
Kind regards,
Elmar
(3,066 Views)
Hello, thanks a lot for the reply!!
I put a snapshot of the point 2.
thanks again!
Mario
(3,042 Views)
Hello Mario,
please go under software and set * so that all user can access to the target.
For more info please look at the attachement.
On tip for the RIO device insert in the empty field in the RIO device:        RI0::INSTR
Dont forget the save button in the upper left corner (in the visa settings and also in the rio settings)
Kind regards,
Elmar
(3,035 Views)
Hi, this is not clear to me and there is no attachment.
thanks!
Mario
(3,023 Views)
Ups sorry Mario,
here the visa print screen from max.
Kind regards,
Elmar
(3,012 Views)
Hello Elmar,
problems are solved!
thanks a lot!!
Ciao
Mario
(3,001 Views)
