convert *.dat to image
Attach your dat file and we figure it out. Also attach your VI.
900x900 is 810000 pixels, but since you are reading it as U16, that would be twice as many bytes. What is the size of the array coming out of the read operation? Also, why do you have a coercion dot on the IAMQ conversion?
Message 11 of 13
(831 Views)
Accepted by tushar.V
@tushar.V wrote:
I'am able to convert *.dat to *.png  image, but i'am getting two images in earth.png
You obviously get a double image if you data is actually U8 , but you are reading it as U16. Now you only have half the required pixels for the full size, so the  reshape will pad with black.
Message 12 of 13
(801 Views)
Thank you it worked.
Message 13 of 13
(776 Views)
