convert .csv to .wav file
Friends,
Need some help converting a .csv file to a .wav file in labview for playing over the speaker. Can anybody please help with a .vi file straight away?
Message 1 of 11
(11,020 Views)
Once the .wav file is to ready, it also has to be played out over a speaker and generate the frequency sweep for the waveform. This speaker generated sound through a NI USB 6009 will then be fed to a filter circuit, and the output of the filter has to be accepted as an input through DAQ NI USB 6009 and microphones to a sound input vi, wherein I need to analyze the magnitude and phase response of the filter circuit. So, I need help with the frequency sweep as well!
Message 2 of 11
(11,011 Views)
19955iFADF8ADE2D08FC3C
Jim
Message 3 of 11
(11,000 Views)
Before you do more work on your project. Have you looked at the 6009 specs here https://www.ni.com/en-us/support/model.usb-6009.html
The 6009 unit have a maximum analog output rate equal to 150 Hz AND the output is software timed. So I think your project is not doable in your current setup. But almost all PCs are equipped with a sound card. And Labview can handle sound cards IO.
@jcarmody
How does your program work? have you tested it 😉
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 4 of 11
(10,982 Views)
Sorry for replying late, but can you please post the .VI file that you made instead of the .jpg file? I'm a newbie here and having a hard time interpreting what signal boxes you used for example, I can't find on my edition of labview the box which you connected to the $csv and wav string constants and the one on which it says ab --> cd file rename.
Message 5 of 11
(10,947 Views)
  1. I need to apologize for my post as it was meant to be a joke.  I'm sorry for misleading you.
  2. My VI only changes the extension of the csv file.  It doesn't do anything to the file contents.
  3. Take a look at what Coq Rouge wrote.  Your equipment might not be adequate.
  4. The image actually contains the code (in LabVIEW 2009) - it's a code snippet.
Jim
Message 6 of 11
(10,945 Views)
@Coq Rouge
Can you please reveal more? Or suggest your solution to the problem?
Message 7 of 11
(10,937 Views)
A Vi tell more than 1000 words. You should post the code you have made so far. So I can an idea of what you are trying to do. It does not have to work.
Message 8 of 11
(10,915 Views)
Ok, I have solved the original issue but need more help. Here are a few more questions:
The "vijaydhwani v2.vi" file is a modification of the typical "generate sound input.vi" file with calculations for magnitude and phase response of a filter. You can adjust the frequency and the amplitude of the sound wave, which I have fed to the digital iir filter block (we have to simulate a low pass 100Hz filter) and the whole set up is used to get magnitude and phase response of the filter.
The "vijaydhwani v5.vi" file is a modification of the "vijaydhwani v2.vi" file, where I have replaced the sound wave element of the earlier setup with another element from the typical "sound file to output.vi" file to read the .wav file.
Now, I eventually solved the conversion issue of .csv to .wav file by saving the .csv file as a .wav file in "Goldwave" (it's a software). The "vijaydhwani v5.vi" plays this .wav file and computes the output. However, I need similar controls as in "vijaydhwani v2.vi", that is I should be able to play the sound file continuously (in a loop?) and have control over its frequency and amplitude. Is that possible? Can you send me a complete modified file of "vijaydhwani v5.vi" that plays the arbitrary sound wave and also give me similar control over it as in "vijaydhwani v2.vi"?
I am attaching the "vijaydhwani v2.vi" file and the "vijaydhwani v5.vi" file
Message 9 of 11
(10,877 Views)
Accepted by topic author Karmasura
As it happen, you had some luck. As I allready have done such an example. Is the NI-6009 out of the picture?
Message 10 of 11
(10,863 Views)
