How can I share Clock via fpga ?
From cRIO NI 923*, we can choose 'Export Onboard Clock' checkbox to share the clock with other modules in the same chassis, while other modules (923*) can use the shared clock as the 'Master Timebase Source'.
Now, I have developed a generic module with clock export from DIO of module interface (Dsub 15), which in one slot, is there any solution that i can get this clock from other slot? Intuitively,  i need to create a wire through chassis FPGA connecting input IO of a slot and output IO of other slot.
Thanks a lot in advance
Message 1 of 1
(2,512 Views)
