04-04-2006 03:39 PM
04-04-2006 03:47 PM
09-14-2009 10:58 AM
09-14-2009 11:31 AM
If your Booleans are in an array, then you should have no problem. If they are not for some reason, just use the Index Array function.
This is very basic. Have you seen the free tutorials?
09-14-2009 11:38 AM
The LED (boolean) indicators are simply placed into an array.
To "borrow" an example of such a display, you could have a look at the code written for the parallel port example that can be found under the Help menu:
Help > Find Examples : Search "parallel" HAve a look at the 1st or 2nd example. They have LED's wired to a U8 array (I think.. It's been a while since I looked at the example... 😉 )
09-15-2009 01:08 PM
09-15-2009 01:43 PM - edited 09-15-2009 01:46 PM
Your image is impossible to see and understand. Perhaps you can post the actual VI? (.png files are better to post than jpeg's. You should search online for the Code Capture Toolkit.)
Why do you have two outputs? What does each mean? If you weren't thinking computers and LabVIEW and you were doing this in your head, how would you handle these two "outputs"?
Why don't you just combine the values into true dates and do a subtraction between them?
09-15-2009 01:57 PM
09-15-2009 02:05 PM
The .pdf is a bit clearer.
True dates as in Time Stamp controls.
09-15-2009 02:06 PM
Okay, if you really want some help, DO NOT poset some code in a pdf file. Creating a pdf is silly since all you have to do is attach an image and the best way to get help is to post an actual VI.
