convert 5 number manually to array
Hi Himmel,
you need to use (and understand) shift registers - as mentioned before!
Message 11 of 15
(2,568 Views)
You need five different values or same value five times
if five different values and values are generated dynamically place the value generation or aquisition inside for loop which will provide five different values
if same value five times feed same value to all five index in this case you dont need loop
Message 12 of 15
(2,560 Views)
Accepted by Himmel
Instead of 1 large wait, perhaps you should use a smaller wait inside of your loop.  This would better simulate a sensor sending you data.  And then you just use the autoindexing tunnel to make your array.  So since you want 5 readings in 2 seconds, a 400ms wait should work for you.
Message 13 of 15
(2,547 Views)
thank you !
I am new by Labview . I  have another question .  in which Platte I can find DBL als control and Array?
Message 14 of 15
(2,535 Views)
Those are terminal.  You create controls on the front panel.  Array container in the array palette.  Double in the numeric palette.
These are very basic LabVIEW quesitons.  I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
Message 15 of 15
(2,533 Views)
