convert 1D array element to integer
My problem is similar. The output is 1D array of double and I would like to extract data from the output. I dont understand the solution you posted therefore would like to clarify with you. I dont think there's a need to attach a VI as I just want to know how to get data from a 1D array (double).
Thanks!
Vanessa
Message 11 of 14
(5,749 Views)
Thanks!
Vanessa
Message 12 of 14
(5,749 Views)
Hi Vanessa,
please go through all those free LabVIEW courses offered by NI on their website to learn how to use the IndexArray function…
You really have problems to understand how this function works?
Message 13 of 14
(5,746 Views)
Similar is NOT the same. An 1D array is data too. Do you want a single element? ... a subset? What do you want to do with the extracted  "data"? (e.g. use ot for further computations, display it in an indicator, etc.)
Index array was mentioned. In what way does it not work for you?
It does not really matter what you think if we want to see some code to clarify the question. You really need to show us at least a picture of the code to get more detailed help.
Message 14 of 14
(5,743 Views)
