controlling radio buttons with an event structure
I am trying to get an equal event in an event strucutre as I programmed ago on year. But now I can't find it.
I have radio buttons on my frontpanel. These I added previously to my event structure as you can see in the Blockdiagram.PNG with "Radio Buttons.Projekt-Button":Value Change. But now I wanted to do the same again by adding a new case to the structure and I am not able to select a certain element of the radio buttons. I can only choose the radio buttons as the whole group like you can see in the Blockdiagram.PNG.
Does anyone has a suggestion for me, how to get the same again?
Soleil20
(3,928 Views)
Hi Soleil,
"Radiobuttons" act as just one control regardless of the number of the buttons in it: it's datatype is an enum!
So you can only have one ValueChange event. To know which button has been pressed you need to evaluate the current value of your radiobutton…
Edit:
Well, you might create a reference for each button in the radiobutton. Then you can register events for each single button, but I still think using the event for the radiobutton itself is easier…
(3,924 Views)
Hi GerdW,
I know this fact. But I am sure, that I was able to select "Radio Buttons.Projekt-Button" of adding an event case. And now, as you can see, I only get the whole Enum.
Soleil20
(3,920 Views)
Hi Soleil,
did you use a cluster of several buttons before?
With a cluster you can create events for cluster elements! (Also the syntax is like in your image "Cluster label", point, "Cluster element name"…)
(3,912 Views)
Accepted by Soleil20
Hi Gerd,
thanks that you helped me. I found the solution.
First I had several buttons like you mentioned. For these buttons I added event cases. Then I found the radio buttons and chose to get them into the radio buttons cluster. And the event case automatically changed from "element":"value change" to "radio button" "point" "element" : "value change".
Soleil 20
(3,910 Views)
