controlling DIO Ports with DAQ1200
who knows how to control the 3 DIO Ports at the same time with that box.
There is always a resetting (initializing) of the other channels when I set
another, even so when I wire a 1 on the initialize pin of the easy DIO
write.vi. Has anybody some more experience with it.
Nice greetings
Herbert
(2,640 Views)
Hi Anja,
The higher level VI's (like easy DIO write.VI, if I remember correctly) will open and close connections to a device. If you would like to do continuous operations to a device with the resets, try one of the lower level VI's or take a closer look at what's happening inside the VI you are working with. (Sorry, No LabVIEW on this machine. Just rebuilt it, you know teenagres...).
What you want to do is open a connection one, do all of your I/O, and only close the connection when you want to exit.
Ben
(2,640 Views)
Anja;
If you use the Easy DIO VIs to control the digital ports, at each time you call one of those VIs, the whole thing is reconfigured.
The way to go about that is to use the Advanced VIs so you have more control over the initialization of the ports.
Hope this helps.
Filipe
(2,640 Views)
