09-30-2010 09:15 AM
Hello.
I use a control system (not from NI) that runs at vxWorks 6.3
In the moment I use a win32-dll in my LabVIEW-application to communikate via Ethernet with my control system.
In the moment, I use the normal LabVIEW-version (not LabVIEW RealTime Module).
In the moment, my application is not able to run in realtime.
idea: Is it possible to create a RealTime application by using LabVIEW-Realtime Module and download the RealTime application with a runtime to
my control system?
The Task-system of the control system should call the Labview-application in realtime
I would like to know, if there is a possibility to habe a realtime-communikation between my control and a LabVIEW application.
Is it possible to run a RealTime LabVIEW application with a controler (running at vxWorks 6.3) in a stand-alone system?
10-01-2010 04:39 AM
The LabVIEW Realtime Module includes a realtime OS. Dependent on the target system, the RT OS is VxWorks 6.3 with current LV RT versions.
What is the target system you are using? Is it a desktop PC?
You might want to take a look into the following white papers on ni.com:
Building a Real-Time System with NI Hardware and Software
Converting a Desktop PC into a Real-Time Target
This tutorial can also give you some valuable hints about using LV RT in your environment.
hope this helps,
Norbert
10-01-2010 07:14 AM
Hello Norbert,
my target is a IndraControl L65 PAC.
There are a lot of discriptions if you use a syste of National Instuments. My PAC ist not
from NI. This makes it difficult, because its not easy to get support for external systems.
see also:
http://www.automation.com/content/rexroth146s-indracontrol-l65-pac
This ist not a desktop PC.
For the visualisation (switching the Buttons for example) would like to create by a Browser or a Network Variable.
The visualisation does not have to be real-time capable.
Only the application should be real-time capable.
10-01-2010 07:14 AM
Hello Norbert,
see also:
10-13-2010 08:09 AM
Currently, LV Real Time is only executable on targets which accept the NI version of VxWorks. That means that the LV Real Time is focused on NI hardware and i doubt that it will run on the PAC you are mentioning.
Nevertheless, NI is always interested in knowing about requests like this so i suggest to contact your local NI representative in case you have similar interests.
thanks,
Norbert
10-14-2010 01:25 AM
Thank you for your answer.
I`ve got in touch with a support engineer of NI a few days ago.
He also said, that LabVIEW realtime is only available for NI products.
anyway, when I use the same vxworks version like NI, why It can not run with the PAC system I am using?
10-14-2010 04:44 AM
NI made several changes to VxWorks. But those changes are in such extend that NI cannot support a different version of VxWorks even if the version number is the same.
10-14-2010 06:53 AM
I think I understand what you mean.
Althougt I have the same version of vxworks like NI, it will not work because NI made changes in vxworks?
But I don't think that NI is able to make changes in the operating system.
I could only be that there is not a runtime available for my PAC system, I think
Your name is Norbert, so I think you are from gemany.
do you also speak german?
