control properties change massively
Good morning,
I am using LabVIEW 8.6.1 and I have the following problem. I can't assign properties to every single control that I put on the front panel of a vi. More specifically, I can’t assign different data entry properties to different controls while it is possible to assign different display format properties to different controls. This is true for every vi new or previously created.
I would appreciate if somebody could help me with this.
Best regards
(2,595 Views)
Accepted by topic author LW42
Are you experiencing something similar to this?
http://forums.ni.com/t5/LabVIEW/Data-Entry-Maximum-and-Minimum-affects-all-objects-on-front/m-p/8549...
___________________
Try to take over the world!
(2,579 Views)
Thank you very much tst. The link proposed was exactly what I was looking for.
Best regards
(2,541 Views)
