control bluetooth in Motorola Q phone
I need help.
I would like to use labview control the bluetooth in the Motorola Q phone that use Windows Mobile 5.
First I use "bluetooth discover.vi" to search the local bluetoth hardware but it returns 0 devic.
Second. I try to install WidComm driver to the phone by using these stpes:(NI webpage instruction)
"Complete the following steps to install the WIDCOMM Bluetooth DLLs
         Connect to ActiveSync on the host computer.
        On the host computer, run labview\PDA\Utilities\Bluetooth\Setup.exe to install the DLLs on the device."
But the phone display
"Unable to install these dll"
How do I go from here?
Thank you in advance.
(2,970 Views)
If you are Searching from your computer, then make sure that you have not installed any drivers that come along with your Bluetooth. Let windows install the drivers of the bluetooth automatically because labVIEW works with windows drivers only
See this
Somil Gautam
Think Weird
(2,960 Views)
The bluetooth device is install by Dell (build in bluetooth) and no problem with windows xp
I check in "hardware manager" and see driver "Broadcom Corporation" version 6.2.0.3500
That means I need to unsitall this driver and install the Windown Microsoft driver?
If so where I can find the window driver ? Beside that my laptop use service pack 3 it should have the Microsoft driver?
Thank you for your time and helping me.
TP
(2,933 Views)
See, what i did was, i simply plugged in the bluetooth device and allowed windows (XP) to install the drivers on its own.
You need not download them from anywhere.
Try uninstalling the drivers (non-windows) of your bluetooth and let windows only install the drivers automatically for you.
For more help, read this article. It should work
Somil Gautam
Think Weird
(2,915 Views)
