how to resize bmp?
I can read a bmp and display it.
but if i load a 1024*768 is too big to display.
How do i resize it into a smaller window?
I mean how to make a big graph fit to a smaller window?
(the vi I found in forum)
Message Edited by nicesg on 05-03-2006 09:52 PM
Message 1 of 13
(6,899 Views)
Modified your VI to shrink the image.
Use the zoom factor property node as shown
For example, to decrease the size of the image to 50% of its original size, wire a value of 0.5 to this property. To increase the size of the image to 200% of its original size, wire a value of 2 to this property.
Its optional if you want to use the draw area size property.
hope this helps
Dev
Message 2 of 13
(6,834 Views)
Smiley Very Happy
thanks Dev, that is what I need!
but I am still thinking change it more suitable zooming, maybe...it can increase with or high individually...
I mean I create a control before (draw area size) it will use handle to change size...
Message 3 of 13
(6,819 Views)
how about this
Message 4 of 13
(6,815 Views)
well, stretching in one direction( height, width) cannot be done with picture function in LabVIEW. i am not aware if there are any addon toolkits for achieving this.
and i could not open your Attached VI. it must be in LabVIEW 8.0 or higher Smiley Sad
Message 5 of 13
(6,814 Views)
I had to handle that problem before & made this VI. The Main-VI is "load and scale picture 24-Bit Map V 2.vi" and the work-doing Sub-Vi is "Scale down V 2.vi". Some of the comments are in german, I hope this doesn't matter too much.
And I have to admit, it's not very fast.
Dave
Greets, Dave
Message 6 of 13
(6,801 Views)
An  implementation I did once can be found here. It will stretch or "compress" the image as needed and can either maintain its aspect ratio or distort it to fit a specific size.
___________________
Try to take over the world!
Message 7 of 13
(6,796 Views)
Try Image Toolbox
George Zou
Message 8 of 13
(6,789 Views)
thanks guys!
I am trying use (zoomfactor) contral (drawareasize).
it is not working...
still trying...
hi, Dev, I use my company's labview8. I do not have labview8 also. = )
Message 9 of 13
(6,769 Views)
Smiley Very Happy
hi,guys, I get it!!
try this!!
Robot Very Happy
Message 10 of 13
(6,765 Views)
