control Keysight trueform 33600 Waveform Generator
I installed NI VISA and the waveform generator driver “Agilent 3352X Series”. But when running the example "Agilent 3352X Series Arbitrary Waveform.vi, I found that there was something wrong with the Sample Rate. The value I set is 10133333.33, but when writing to the Keysight trueform 33600 Waveform Generator, the last three digits will become zero, and the fourth-to-last digit will be rounded off. Can anyone help me with this problem? Grateful!
我安装了NI VISA以及波形发生器的驱动Agilent 3352X Series,运行生成任意波范例“Agilent 3352X Series Arbitrary Waveform.vi”时,发现发送信号的Sample Rate写入有些问题,我设置的值是10133333.33,但是写入到信号发生器上时,最后三位数字会变成零,倒数第四位数字还会出现四舍五入的现象,有谁能帮我解决这个小问题吗?感激不尽!
(2,798 Views)
Accepted by topic author JINGCI
Hi Jin,
the problem is inside the "Configure Arbitrary Waveform" subVI. Unfortunately you forgot to attach that specific subVI…
(2,758 Views)
Hi GerdW,
    Thank you~
    The problem is indeed inside the "Configure Arbitrary Waveform" subVI. I edited the format of string to %f.
(2,735 Views)
Hello JINGCI,
Please can you share what you changed exactly, i have this now "SOUR%d:FUNC:ARB %s\n".
Best regards
(2,125 Views)
JINGCI posted this 2 years ago and probably won't be back to answer questions.
In the string you post, "SOUR%d" is the selection of which channel to modify, and "FUNC:ARB %s" is just choosing the name of the waveform data saved on the device.  Neither one can be changed to %f like the solution implies was needed.
It was more likely that what he changed was this:
"%.;SOUR%d" just sets the decimal separator to a period then selects the channel, but the second half, "FUNC:ARB:SRAT\s%g\n" has the "%g" setting the sample rate.
If you change that %g to a %f, it adds more precision onto the number:
(2,115 Views)
