continuous to discrete
I am kind of new to labview and need some help. I obtained a set of data(x,y) of a graph and save in lvm file. Then I use the read from measurement file vi and obtained the signal. what I am trying to do is to discretize this signal to a certain time step (i.e. x start from 0 with interval 10). Is there anyway I can do this?
atoz
(4,230 Views)
Discretization in time axis is nothing but sampling, if you've a set of data (an array), and want to perform discretization (in time), you can use decimation tool.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(4,217 Views)
Thanks for replying. but what I want is something like this. for example i have a set of data (both in x and y). example:
x              y
10.123     2345
18.34      3456
29.89      4678
with these data, i use the curve fitting vi to get the fitted curve with new set of data (both x and y). however, i would like to get the value of y for a fix interval value of x based on the fitted curve data. example for time step x = 10, is there a way of doing that?
atoz
(4,211 Views)
There is a direct tool available, check the attached code.
(4,204 Views)
It seems that I am not able to open the file. I am using 8.6 version. Do you have that vi in 8.6 version?
atoz
(4,195 Views)
atoz
Ohhh, please find the downgraded VI in the attachment.
(4,191 Views)
Thank you.. Smiley Happy
(4,148 Views)
