Will Labview 6.0 work with windows 7 32 or 64 bit
We have a machine here at work which is set up running labview 6.0 with windows 98. The pc on the machine is WAY too old. We are looking to replace it and I need to know if this version will run on windows 7 (32 or 64 bit OS), or do we need to run an older OS.
Thanks in advance  for any help.
(2,710 Views)
Did you try a search? https://www.ni.com/en/support/documentation/compatibility/09/national-instruments-product-compatibil...
So, the official answer is no. The practical answer? Maybe. If you can get it to install, that is. Please do a search on installing previous versions of LabVIEW on Windows 7, as this question has also been asked many times.
(2,698 Views)
