continuous curve fitting
@brico33 wrote:
-I've made this study on qtiplot before and it gave the following parameters : -2,3,0,-2 . When I put those parameters in the pogram I got a nice erf function
You might want to look at the order of parameters. If the third parameter is zero, all your x are the same and you get a horizontal line out of the model. As a first step you should use the model subVI using the parameter guesses and an x-ramp over the typical range to see if the output looks as expected. Did you do that?
Message 11 of 13
(878 Views)
Yes I've tested my subVI model and it works fine, I got a good erf function. I've also found other parameters more appropriate than the others one. But I've noticed something , when I start the program (with the run button sorry) all the first parameters are close to the best fit parameters except the parameter C which fluctuates a lot.
Message 12 of 13
(857 Views)
Is that still the same as you uploaded earlier? How much is "a lot"?
How does the data look like?
Can you attach a new VI that contains default data (e.g. as diagram constant) and your typical starting values set to default of the control.
Message 13 of 13
(851 Views)
