continously
In the attached file, the Fast Fourier Transform, de cumulative distribution and the probability density distribution is plotted at the end of the for loop.
How to plot the same graphs while the for loop is running?  (I have LabView version 8.0)
Thank you verymuch,
Francisco
(3,900 Views)
The obvious answer is to place the analysis inside the loop. Smiley Wink
There are "point by point" versions of the signal processing VIs that you can use. For example, there's an FFT PtByPt VI that can be used to calculate the FFT progressively.
For the graphs you'd need to accumulate the data along the way. The best way to do this, since you know the size of the array, is to pre-allocate the arrays and use Replace Array Subset to update the array values with each iteration. If you pre-allocate the array values with NaN for the Y-values then they won't plot on the graph.
(3,890 Views)
Accepted by topic author fgarcia
Her's is a basic example derived from your code that does not use the math functions found only on full and pro LV versionSmiley Wink
"Should be" isn't "Is" -Jay
(3,882 Views)
When you run the example you will notice a small dc residual in the FFT.  I'm not sure what causes this but replacing RMS vi with Mean.vi yields better results.  (I suspect its one of those minor points in statistics that we all tend to forget about)
(3,879 Views)
THANK YOU SO MUCH EVERYONE FOR YOUR KIND ANSWERS!
(3,836 Views)
