construct a signal from saved amplitude &time values in excel sheet
hi
i have an excel sheet consisting of signal amplitudes as shown in below example with respect to their time,please tell me how to construct a signal from them.i am attaching my saved signal excel file
eg:        time    amplitude
              712    0.0424805
              713    0.0297852
                to       to
             1800  0.000283
Message 1 of 11
(4,296 Views)
Hello illa,
your task has two main parts: reading the file and outputting the signal.
The easiest way to read the file is to use the Scan from File VI.
First you have to save your Excel sheet to Text (Tab delimited) format, and you have to delete the first line that contains the labels. The resulting file can be read by the Scan from File VI.
Please see my attached example.
About generating an analog signal you can find a lot of well documented examples in the Example Finder (Help menu -> Find examples). Search for the keyword 'analog output'.
Daniel
Dániel Fülöp
Field Application Engineer (CLA, CTA)
Message 2 of 11
(4,292 Views)
thank you for your reply, i  converted to text file and tried with READ FROM TEXT example but i couldnt get the graph.i am attaching my saved text file please provide me a solution
Message 3 of 11
(4,282 Views)
If you have that kind of file format all you need to use is the Read From Spreadsheet File. You didn't say what kind of graph you wanted, so I just used an XY graph since I didn't know if the data was always going to be evenly spaced.
Message 4 of 11
(4,276 Views)
the waveform you got is the one exactly  i want,but i couldnt find the VI which is conncetd form Read from spreadsheet file, is it an insert in to array,( i rounded it in the attachement)
actually my aim is to plot FFT and power spectrum from then plotted grqph
Message 5 of 11
(4,245 Views)
My picture is a Snippet. You can drag and drop it onto a block diagram. For reference, that's Index Array.
Have you done some LabVIEW tutorials? To learn more about LabVIEW it is recommended that you go through the introduction material, tutorial(s), and other material in the NI Developer Zone's Learning Center which provides links to other materials and other tutorials. There are also several Technical Resources. You can also take the online courses for free.
Message 6 of 11
(4,231 Views)
thank you very much,i am able to display the grap.i need one help from you i want to caluclate the power spectrum of the signal and FFT of the signal is it
possible. from past 9 months i am working mainly Compact RIO configuration and signal acquisition.i never used these file functions.
Message 7 of 11
(4,226 Views)
LabVIEW has FFT and Power Spectrum functions. You will need to specify some parameters, such as the FFT window. The functions are available in the Signal Processing -> Spectral and Signal Processing -> Transforms palettes. There are also Express VI version if you really want to use those, but I don't think you'll need to. If you open the Example Finder and search for FFT, for example, you will find a number of examples.
Message 8 of 11
(4,222 Views)
i am able to do display the graph but i am unable to proceed to FFT i have given my VI in the attached
please help me regarding that error
Message 9 of 11
(4,201 Views)
I don't use Express VIs, so I didn't know that somewhere along the way the Spectral Measurements Express VI changed its "Signals" input from dynamic data to the waveform datatype. You need to take your array of values and put them as the Y component of the waveform datatype. The waveform datatype consists of 4 components: starting time, delta time, array of values, and attributes. You can create a waveform datatype using the Build Waveform function. See attached example.
Alternatively, you can use the FFT VI that's in the Signal Processing -> Transforms palette.
Message 10 of 11
(4,180 Views)
