constrainte
SOLVED
tinnitus
Active Participant
constrainte
Message contains an attachment
hello,
i have trouble with a simple operation : min value
i works if user click on command but not with value initializing numeric, is it a question of block ordering ?
i don't see what it doesn't consider min constrainte on zero value
Best regards
tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
4 REPLIES 4
aeastet
Trusted Enthusiast
Re: constrainte
What are you trying to do here. Do you want the numeric to coerce the value to three if it is less than three?
Tim
GHSP
tinnitus
Active Participant
Re : Re: constrainte
yes
TCPlomp
Trusted Enthusiast
Re: constrainte
what you see is expected behaviour.
The constraints set are only for user behaviour, if you update a control in code you should test for limits yourself.
Ton
My LabVIEW Ideas
Highlighted
aeastet
Trusted Enthusiast
Re: constrainte
Here is how you do it.
Message Edited by aeastet on 04-28-2010 09:46 AM
Tim
GHSP
