connet to wifi network
I have a requirement to connect a windows pc to a wireless router ( i am provided with ssid and password), login and retrieve a html page. I have most of this written in c# but not looking forward to the task of getting the call library function working correctly. Are there any articles on acheiving this wifi test within labview or do i have to brave using the call library function to access my DLL
thanks in advamce
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
(3,210 Views)
Accepted by Akiel
Hi Akiel
I believe you will find the following link helpful, which describes how to call a DLL from LabVIEW:
http://digital.ni.com/public.nsf/allkb/DCB90714981A1F148625731E00797C33
Also if you go to the LabVIEW Example Finder within LabVIEW “Help>>Find Examples...” there is a useful example called Call DLL.vi located under “Communicating with External Applications>>Using External Code>>Integrating DLLs”
Let me know if this is of help, and if there is anything else I can do.
Andrew.N
Applications Engineer
(3,162 Views)
Many thanks, that example deals with the major part of the problem, converting the data types
(3,107 Views)
Hi Akiel
I’m glad you found the link helpful and you got a solution to your problem.
Best Regards
Andrew.N
(3,072 Views)
This link also helped me a lot to solve my issue.
Tks! Smiley Very Happy
Mondoni
(3,055 Views)
