configuring background buffer
I am having some trouble outputing a -10/+10V sine wave at different frequencies to measure bandwidth of a filter. I keep getting a "generation has stopped to prevent regeneration of old samples ... increase the size of the background buffer by configuring the buffer ... " How do I "configure" the background buffer? I've attached some code. Init, Run is the part of the code inside a while loop with increasing frequencies - that is where it usually quits on me - and Quit when I exit the program. I'm using a 6221 PCI (37-pin) and the max frequency I need is only 10K. My DAQ card should be able to handle this shouldn't it? It's update rate is something like 800K.
PaulG.
Retired
(3,794 Views)
Accepted by topic author PaulG.
Why don't you change the Init.VI to allow regeneration of the samples?
(3,762 Views)
I'm a Browns fan and I HATE the Ravens. Smiley Mad
But I tried your suggestion and I think it's working. Smiley Surprised
Thanks. Smiley Happy
PaulG.
Retired
(3,723 Views)
