Is it possible to control a slider with a button? It works like a automatic sliding gate. Is it possible? Where when you open the gate, it will slide slowly.. And can anyone help me with this..
Sure. You will need to have the value of the slider stored in a shift register. If the Button is true, then add some value to to that at some rate determined by your loop rate.
The way this usually works is that I think of a simpler implementation once I click the Submit button...
Jim You're entirely bonkers. But I'll tell you a secret. All the best people are. ~ Alice For he does not know what will happen; So who can tell him when it will occur? Eccl. 8:7
