configuration of labview for sending SMS
hi, i did a program but how do i choose the mobile number. For example, there is a scroll bar for me to select the numbers saved and when i press enter the message will be sent. Thanks
(3,222 Views)
Accepted by gabriellimhj
hi, anyone out there can help?
(3,162 Views)
Good day to you. In the first post you mentioned that you want to select numbers saved. Are you trying to access the phone book in the SIM card and display the numbers which have been saved in the phone book? You will need to use different set of AT commands to access the phone book entries. From here, you will need to do a VISA read to get all the entries. I found a set of AT commands to access the phone book entries:
http://www.forensicswiki.org/wiki/AT_Commands#Phonebook
Alan
Applications Engineer | National Instruments
Singapore (65) 6226 5886 | Malaysia (60) 3 7948 2000 | Thailand (66) 2 298 4800
Philippines (63) 2 659 1722 | Vietnam (84) 28 3911 3150 | Indonesia (62) 21 2783 2355
(3,143 Views)
