concurrent vi execution
I have a system that requires three .vis to be running concurrently.  This architecture is intentional -- I want them to run as separate processes.  Occasionally, a user forgets to start up all three vis.  Is there something akin to a batch file I can create so that this error can be avoided?
Earl
(3,045 Views)
Modern versions of LV will et you invoke VI's via a command line but I would use VI-Server Invoke node >>> Run VI for each of the VIs since I like lV more than bat files.
Ben
(3,042 Views)
Just create one starter VI that just has all three subVIs on its block diagram with no wiring inbetween them. Then the user just always runs this one VI and it will start all three independently.
Jarrod S.
(3,000 Views)
