concetanate arrays
I need to concetanate an array with zeros this way: for example, the original array: 123, created array:102030.
I am struggling with this for a long time, because I am a newbie in labview. The solution must be simple, but I can't find it.
Thanks!
Zoli
Message 1 of 10
(4,513 Views)
Accepted by borzola
Try the attached VI
Ninad Regundwar
Junior Engineer | ARAV Technologies | www.aravtech.com
Message 2 of 10
(4,509 Views)
Thank you, you helped a lot!
Message 3 of 10
(4,504 Views)
kudos are all time accepted
Ninad Regundwar
Message 4 of 10
(4,501 Views)
Your "solution" is undeserving of kudos.  There is absolutely no need to convert to/from strings to perform this operation.
Thanks!
Zoli
That's not concatenation, that's interleaving that you've described.
Jim
Message 5 of 10
(4,484 Views)
you are right, it's so simple this way!
Message 6 of 10
(4,473 Views)
I agree that the string conversion is silly, but would point out that the option selected for the loop output (right click, Tunnel Mode) uses the NI term "Concatenating".
Never used that feature myself; was curious about the unique looking terminal.
See LV2012 Features and changesThanks @tst !
I learned something new today!
Message 7 of 10
(4,469 Views)
That *is* concatenating; I was referring to to the OP's use of the term.  I replaced the concatenating For loop with an Interleave Array node.
Jim
Message 8 of 10
(4,438 Views)
I was obsessed with the strange for loop output that I missed that. I stand corrected Smiley Embarassed
Message 9 of 10
(4,433 Views)
Thanks!
Zoli
Of course if you want to save a couple scalar buffers (that really don't need to be there) and a bit of real estate.
SIDE NOTE: Smart compiler in 2013!  it really only has one of the duplicated array constants allocated.
"Should be" isn't "Is" -Jay
Message 10 of 10
(4,372 Views)
