comunication labview-oscilloscope via usb
hello 🙂
i have to comunicate with a oscilloscpe via usb port...well i have no idea in what way i could do it 🙂
someone can tell me which blocks i have to use to comunicate?
via rs232 i used visa read and write blocks....via usb?
thanks
Using LabVIEW 7.1
Message 1 of 10
(3,512 Views)
It will still be a visa resource. Look for labview drivers for your specific scope here https://www.ni.com/en/support/downloads/instrument-drivers.html or the scope makers' website.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 2 of 10
(3,496 Views)
i use labview7 😞
as you can see it's not present...and now? 😞
PS: in what way can i use driver? :=) i install them...and then? 🙂
Using LabVIEW 7.1
Message 3 of 10
(3,494 Views)
Unfortunately, I can't go back that far but you can post a request to save the 8.2 driver to version 7.0 here: https://forums.ni.com/t5/Version-Conversion/bd-p/VersionConversion
Message 4 of 10
(3,491 Views)
after installed my drivers (i hope to find them) what i have to do?
does someone have an example in labview 7.1 about comunication via usb? in what i must configure my port, etc...
thanks again
Using LabVIEW 7.1
Message 5 of 10
(3,482 Views)
USB support was introduced in visa 3.0. I am not sure which version you are using and the how labview 7.1 will work with it!
Here is a tutorial if thats of any help: https://learn.ni.com/learn/article/getting-started-with-instrument-control-hardware-and-labview
Message 6 of 10
(3,476 Views)
visa 5.x 🙂
Using LabVIEW 7.1
Message 7 of 10
(3,474 Views)
if i try to comunicate via ethernet, are drivers required?
Using LabVIEW 7.1
Message 8 of 10
(3,452 Views)
@gigi85 wrote:
hello 🙂
thanks
The oscilliope manual should be very helpful with this. Try reading it.
Message 9 of 10
(3,445 Views)
it tell nothing... 😞 just 2 things...
i download programmer manual (for remote control) and it's 99% full of comands only
Using LabVIEW 7.1
Message 10 of 10
(3,430 Views)
