This widget could not be displayed.
compile sever error
I have a problem with compilation. I'm working with Crio 9076 and when I wanted to compile my code to FPGA, error message occured (error.compiler.jpg).
Do you know what is problem, and how can I fix this error?
Thanks in advance.
Message 1 of 8
(3,799 Views)
I believe it is a problem with you compiler. Did it started compiling and stopped after a while? or it is not connecting to compiler at all?
Kind Regards,
Ion R.
Message 2 of 8
(3,776 Views)
I send picture that show what's happening step by step...
I realy don't understand what is a problem?
Message 3 of 8
(3,767 Views)
The problem is that LabVIEW FPGA can not connect to farm compiler.
1. Do you have activated FPGA Compile Farm?
2. If you have it activated please try to lunch it manually:
 Start  / Programs / National Instruments/  search for Compile Farmer Worker and lunch it.
Than try to compile your code again.
Kind regards,
Message 4 of 8
(3,762 Views)
I lunched it manually before compiling (FPGA Compile Worker.jpg) but the problem is still present.
Can You explain me in more details how to activate FPGA Compile Farm?
I'm working with cRIO first time.
Message 5 of 8
(3,758 Views)
After clicking on FPGA Compile Worker, in the bottom right corner you should see the icon of FPGA.
Tell me what is the status of it.
Kind regards,
Ion R.
Message 6 of 8
(3,750 Views)
This is before compiling.
Message 7 of 8
(3,743 Views)
It seems that LabVIEW FPGA can not connect to FPGA Compile farmer.
You can try to reinstall LabVIEW FPGA , this might solve the issue.
Kind regards,
Message 8 of 8
(3,723 Views)
