comparing timestamps using shift registers
I'm confused. How do you make TIME update randomly by putting it into different loops? LabView is powerful, but making time move about randomly?
Glad to answer questions. Thanks for any KUDOS or marked solutions 😉
Message 11 of 21
(2,406 Views)
Data is being generated by a controller. Everytime that data updates, the time when it updated is shown in a timestamp.
Message 12 of 21
(2,401 Views)
Ok, it was a grammar thing...
Look at this. I hope this isn't homework. It could be done cleaner, but this will give you an idea.
Message 13 of 21
(2,380 Views)
Hi Patrick,
I use LabVIEW 2013 and cannot open the test VI you sent.
Thank you for resending.
Message 14 of 21
(2,370 Views)
Accepted by TeamHalli
You'll need the open G toolkit
Message 15 of 21
(2,363 Views)
Do you need to do it by feeding in timestamps? Why not just run it right next to where your data pops out?
Message 16 of 21
(2,351 Views)
Thanks to the way you uploaded your zip file, it includes the Boolean Trigger function already.
Message 17 of 21
(2,349 Views)
Yes Gregory I need to use the timestamp...
With a minor change from Patrick's test VI, I was able to get the solution I was looking for.
Thank you!
Message 18 of 21
(2,332 Views)
You shouldn't put your x and y controls inside the case.
Message 19 of 21
(2,323 Views)
By the way, this snippet I showed would be part of a larger code, so the X and Y variables inside the case structure would be local variables. Is that OK?
Message 20 of 21
(2,317 Views)
