comparing sine and triangle waves
hi everyone, hereby to tell that the problem is solved. i just had to change the "dt to waveform" with a red dot to one with a blue dot (on the top). i don't know what the difference is, but i'm happy it's solved.
THANKS to everybody that helped me out !!
Message 11 of 19
(2,293 Views)
hi everybody, me again...
i have a new question regarding this matter. is there a way that i can only compare the positive values of the sine wave?
so i get an PWM signal only for the positive values and just zero for the negative values.
i've tried various things but it doesn't work out the way i want it.
again thanks in advance
Message 12 of 19
(2,266 Views)
hello everyone, problem is solved. by comparing a few times i have now the correct signal. sorry for the bother
grtz
Message 13 of 19
(2,249 Views)
Please, could somebody convert this VI to labview 7, because I am not in my computer and I only have labview 7.0
Thank you very much
Message 14 of 19
(2,042 Views)
Hello mvinicio,
Currently I only have LabVIEW 2011 installed, but normally you should be able to recreate the VI by yourself.
I have added a screenshot on which you see the labels of the VI's.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 15 of 19
(2,022 Views)
Hi
Sorry, only have 2011 as well. There is an entire board on the forum just for version conversion. Post the VI or a link to this discussion there.
Best Regards
David
Message 16 of 19
(2,019 Views)
could u please give me the solution for thi queston if u have got it
Message 17 of 19
(1,752 Views)
Hi Kapoew,
grtz
could you share the solution, so... me or another person what have the same problem can learn from you. many thanks
Message 18 of 19
(1,733 Views)
Hey mubzzz, hey JimmyAndrianto,
As Kapoew's post is from 8.5 years ago, he/she might not respond to your question. Probably you will be helped towards a solution faster when you open a new thread, describing your current situation, your goal, and posting your current code.
Ingo – LabVIEW 2013, 2014, 2015, 2016, 2017, 2018, NXG 2.0, 2.1, 3.0
CLADMSD
Message 19 of 19
(1,722 Views)
