compare images
Hi...
I like to compare two images such that one should be taken continuously and another should be already stored in memory.
And how to store images...
Message 1 of 13
(4,019 Views)
mano94chitra@gmail.com wrote:
Hi...
can you provide more info, what excatly are you comparing in the image. There can be many ways. One of them is to subtract the image. You can also convert your images into array , do the subtraction on those both array and check.
you also might wanna check this : IMAQ compare
Message 2 of 13
(4,010 Views)
Try this
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 3 of 13
(3,985 Views)
Hi..
I like to compare nose,lips and eyes of  two faces by capturing one image and another to be already stored.
Message 4 of 13
(3,959 Views)
Hi..
Message 5 of 13
(3,959 Views)
The pixels will vary accordingly..Whatever you compare doesnt matter.
--Ranjeet
Message 6 of 13
(3,935 Views)
Hi...
Thanx for your reply...
But I don't get what you are saying...
I just want to do face recognition by using eigen face vector..
Is it possible to do using labview?
Message 7 of 13
(3,920 Views)
Try this. Why eigen?
--Ranjeet
Message 8 of 13
(3,901 Views)
Hi...
My idea is to compare two images...
First I have to extract the features such as area of ear,lips,nose and width of forehead and then store in a database..
then I have to capture the image using webcam then extract the features from it and that extracted image data should be
compared with the already stored data in the database...
Is it possible to do??
Message 9 of 13
(3,875 Views)
Do you have the IMAQ library ?
You can do a transposition of the x,y image pixels into a fourier representation.
Subtracting the F-Images you may get the corresponding areas to compare.
But all this is real hard stuff.
Good luck.
7.1 -- 2013
CLA
Message 10 of 13
(3,866 Views)
