compare current value with previous value
I would like to compare the current value with the previous value of the current value.prev.jpg
How can I solve this problem?
Maurits
(4,837 Views)
You will require a loop and a shift register/feedback node.
You should start with NI LabVIEW Basics.
hope this helps,
Norbert
Norbert
Expert: Geometry
(4,831 Views)
after going through the basics course you surely can understand that example:
(4,826 Views)
