compare connector pane programatically
Can we comapre the connector panes of two VIs prgramatically?
(3,227 Views)
Hi Pritam,
yes it´s possible with scripting.
Mike
(3,225 Views)
Can you explain in detail?
(3,219 Views)
Accepted by topic author pritam
Hi Pritam,
if you use the attached vi, you get information about the used pattern and which object is connected.
Hope it helps.
Mike
(3,212 Views)
Thanks Mike. But I cant find this property in my LV 8.5.1. Is it outaded? see the attachemnt to see what properties I can see.
(3,195 Views)
Hi Pritam,
no it´s not outdated. It´s a private feature. See this link.
Mike
(3,189 Views)
