compare connector pane programatically
Can we comapre the connector panes of two VIs prgramatically?
(3,521 Views)
Hi Pritam,
yes it´s possible with scripting.
Mike
(3,519 Views)
Can you explain in detail?
(3,513 Views)
Accepted by pritam
Hi Pritam,
if you use the attached vi, you get information about the used pattern and which object is connected.
Hope it helps.
Mike
(3,506 Views)
Thanks Mike. But I cant find this property in my LV 8.5.1. Is it outaded? see the attachemnt to see what properties I can see.
(3,489 Views)
Hi Pritam,
no it´s not outdated. It´s a private feature. See this link.
Mike
(3,483 Views)
