compactrio compiling FPGA
Hi!
I have a cRIO 9022, LabView 2011 with all the licenses and patches that are required to compile, but every time i try to compile the project with my local computer (the development computer) there is a message which said "The compilation tools are not installed". Any idea?
i will appreciate your collaboration with this
(4,101 Views)
Seems that you installed LV FPGA without the Xilinx Compile Tools. You can download them from here:
LabVIEW FPGA Module Xilinx Tools 10.1
LabVIEW FPGA Module Xilinx Tools 12.4
Usually both of them get installed with LV FPGA 2011. The compiler decides which one to use regarding the FPGA Target you are using.
Christian
(4,088 Views)
Hi Christian
Thanks for your answer i already solved it, i think you are right, there was something missing, when i reinstall labview and all the modules it works.
thanks.
(4,070 Views)
Hi All,
both links are broken now. Do Xilinx Tools 13.4 work together with LV 2011 FPGA Module and CRio 9075 (Spartan 5)?
Regards
PioB
(4,033 Views)
Hi PioB,
I can open both links and get some (huge) downlads presented...
(4,027 Views)
