compactRIO FPGA Build Specification properties
Hello
I'm following this guide in particular: LabVIEW FPGA Sample Project - But i am also experiencing the issue in all other projects that i do
To set the FPGA for "Run when loaded to FPGA" i must open the build specifications as shown here
However, when i do this i encounter the following error:
The full error text says:
Possible reason(s):
LabVIEW: File not found. The file might be in a different location or deleted. Use the command prompt or the file explorer to verify that the path is correct.
NI-488: Nonexistent GPIB interface.
Complete call chain:
Get LV Class Default Value.vi
AB_UI_Initialize_Framework.vi
AB_UI_FRAMEWORK.vi
niFpgaBuild_Item_OnDoProperties.vi
niFpgaComp_Item_OnDoProperties.vi
niFpgaComp_Item_OnDoProperties.vi.ProxyCaller
LabVIEW attempted to load the class at this path:
<Empty Path>
Even if i try to redo the FPGA Main from Build Specification > New > Compilation I can check the property "Run when loaded to FPGA" - but am i not able to re-open the properties after it has run? I get the same error.
(4,966 Views)
I also noticed that in my project explorer i do not have the FPGA icon for the build specifications, but instead i have a questionmark like this
Does this indicate anything regarding the error?
(4,945 Views)
Do you have the FPGA toolkit and CompactRIO drivers installed? If you look in MAX under software, do they appear under the version of LabVIEW you have installed and/or the software list? The question mark in the build specification usually indicates that the FPGA toolkit isn't installed/licensed correctly.
(blog)
(4,922 Views)
I have both Compact RIO drivers and FPGA Module installed for LabVIEW 32-bit.
However, the FPGA toolkit you are talking about. For the compiler I have downloaded and installed just the LabVIEW FPGA Module Xilinx tools.  Is there something extra that i need?
Edit: Searching on google for the "FPGA Toolkit", i found the LabVIEW 2015 FPGA Compile Farm Toolkit - which i haven't installed. Is that what you are referring to?.
(4,912 Views)
Sorry - yes, I meant the FPGA Module - it should be installed under 'LabvIEW 32-bit' in MAX.
To build an FPGA VI - you need to either use the compile farm (to compile the FPGA on NIs servers) or the Xilinx tools (to compile locally on your computer).
(blog)
(4,898 Views)
I have FPGA Module for 32-bit LabVIEW
Edit:
This morning i saw that i had an update for
LabVIEW 2015 FPGA Module Xilinx Tools Vivado 2014.4 f1 Patch
When trying to install i get the following error
When i search for "Ni LabVIEW FPGA Xilinx Vivado HLS 2015" all i find is this download page which is the exact tool that i have already downloaded and installed.
(4,873 Views)
Accepted by topic author asgerbj
I solved the issue by uninstalling all National Instruments software, and reinstalled in the following order:
LabVIEW 2015 (32-bit) http://www.ni.com/download/labview-development-system-2015/5308/en/
LabVIEW 2015 (64-bit) http://www.ni.com/download/labview-development-system-2015/5314/en/
LabVIEW 2015 FPGA Module http://www.ni.com/download/labview-fpga-module-2015/5461/en/
LabVIEW 2015 Real-Time module http://www.ni.com/download/labview-real-time-module-2015/5451/en/
LabVIEW 2015 FPGA Xilinx Tools http://www.ni.com/download/labview-fpga-module-2015/5492/en/
NI CompactRIO 15.0 http://www.ni.com/download/ni-rio-15.0/5363/en/
After i was able to update the urgent f1 patch for LabVIEW 2015 FPGA Xilinx Tools in the NI Update service manager and the issues have been fixed.
(4,779 Views)
