communication cFP and PLC
I have some questions concerning Profibus communication between a Compact Field Point system and a Siemens PLC.
The following hardware is used:
NI cFP 2120 controller
Siemens S7 314 MPI
Has somebody tried to read data from a Siemens PLC over the RS485 ports with profibus?
If yes, could we get the (Siemens) command set so we can try to retrieve data from the PLC (using NI-VISA).
Or has somebody already programmed a solution, could we then have an example of how it has been programmed.
Has somebody solved this problem of communication in a different way? What was the solution and how much time / money did it take.
Hope someone could help me with this problem.
Already thanks for the effort.
(2,575 Views)
I have not tried communicating with a Siemens PLC before, but I have been able to communicate with a WAGO PLC with LabVIEW by using an OPC Server installed on the PC. Using an OPC server that can communicate with a Siemens PLC should give a similar result. You can get a siemens PLC OPC driver from www.matrikon.com (by purchase). Some more documentation on this driver is avaliable at http://www.matrikonopc.com/opc-drivers/1329/index.aspx#html with a free registration.
Hope this helps
National Instruments LabVIEW beginner video tutorials available at www.fafiles.com. Get Wired Up!!!
(2,562 Views)
