comments on vi
i have a lv project with a main vi.I copied it to my laptop,instead copying the whole project,i copied only the vi by mistake.i added all the comments for the code in the vi.now when i copy the commented vi back to the project folder,it is not happening.
please help me to fix this.
Message 1 of 12
(5,136 Views)
Hi krupa,
what exactly is "not happening"?
Message 2 of 12
(5,126 Views)
When i copy the main vi that has comments,to the lvproj folder,the old vi is not overwritten by the new one.
Message 3 of 12
(5,116 Views)
Hi krupa,
why can't you overwrite the VI?
Don't you have access rights to that folder/file?
What happens when you close LabVIEW and restart it. After restart open the VI and/or the project…
Message 4 of 12
(5,100 Views)
use save as and then select duplicate hierarchy to new location
Message 5 of 12
(5,095 Views)
When i close,reopen it(vi,lvproj)..it is opening.i do not see any error..its working fine..just the copying is not happening
Message 6 of 12
(5,092 Views)
As i am copying from other location,the path seem to have changed.
how can i correct this??
Message 7 of 12
(5,065 Views)
Hi krupa,
lesson learned: don't copy single VIs from a project from one computer to an other!
How to correct? Follow the advices in the dialog shown in your image…
Message 8 of 12
(5,030 Views)
did you use  save as and then select duplicate hierarchy to new location?!
after that just close old vi and open from new location
Message 9 of 12
(5,019 Views)
Another mess that proper Source Code Control would have prevented.
It looks like you tried to open up the VI from another location.  Why were you unable to copy the file back overtop where you originally copied it from?  Sounds like a permissions issue.
Message 10 of 12
(5,001 Views)
