combo box
hi,
I have added items to a combo box.
how can i send those items to the database(ms-access)?
tell me how to do this in labview?
InAdvance Thanks
Regards
Soundarya
Message 1 of 10
(5,239 Views)
You can use the Database and Connectivity Toolkit!
Message 2 of 10
(5,227 Views)
How many threads are you going to create . Please continue here
Message 3 of 10
(5,223 Views)
hi, I have some list of values in the database like:ate,hal,shop and qc.
so i want to update the field value in the database for example "from ate to ni"
i have written an update statement, but all the values are getting updated. i want to update only one field when i click a particular value in a combo box
can u tell me how to write the sql statement for this?
InAdvance Thanks
Regards
Soundarya
Message 4 of 10
(5,186 Views)
You must post this to SQL forums?
- Partha ( CLD until Oct 2027 🙂 )
Message 5 of 10
(5,184 Views)
Hi Soundarya,
can you show what you have done so far? Maybe you can also upload a part of your database.
Did you make a search for "update"?
Mike
Message 6 of 10
(5,169 Views)
hi,
i will explain u what I want exactly.
i have a combo box in my vi. in that i have added items like:shop,qc,qae and sqae.
so i want to update that shop, qc,qae and sqae. and i have all these values in my ms-access too.
i have used db connectivity tool for updating, but it is updating each value.
but my requirement is: whenever i click a particular value in a combox box, only that value has to get updated. how can i do this in labview?
Regards
Soundarya
Message 7 of 10
(5,161 Views)
Hi Soundarya,
you can use an event structure. In the value change event of your combo box, you can read the selected value and build your update query.
It should be something like this:
UPDATE table SET columnname='new' WHERE columnComboBox='selectedValue'
Mike
Message 8 of 10
(5,153 Views)
hi,
i have done the samething as u said before itself.
but my doubt is what is that selected value u have mentioned. i mean how do u get that?
InAdvance Thanks
Regards
Soundarya
Message 9 of 10
(5,149 Views)
Hi Soundarya,
please see the attached picture.
Mike
Message 10 of 10
(5,141 Views)
