combo box
Hi
Could someone help me please. My problem is, I have 2 comboboxes and when I select an item from the dropdown list of my 1st combobox, the items in the dropdown list of 2nd combox must change accoring to the item selected in the 1st combobox
For example if I select TLC2274 in first combobox it should show OP-1, OP-2, OP-3 in the 2nd combox and if I select LM2903 it should show OP-1, OP-2.
The items in the 1st combobox are .csv files which contain pin numbers and pin definitions of opamp. Thankyou in advance
Pratheek
Message 1 of 12
(4,526 Views)
You can use the 'Strings []' property, in a property node, to programatically define the content of a combo box.
Message 2 of 12
(4,520 Views)
Message 3 of 12
(4,512 Views)
Hi Phil_
I am fairly new to Labview.....Could you please explain in detail or post any example VI's if you have any........ I am using string property node but how could i get the values in my 2nd combox changing according to the items selected in the 1st combobox using string property node ? could you please give me few suggestions....
Message 4 of 12
(4,508 Views)
I am unable to open it....I am using Labview 10. Could you please save it for previous version and post it....
Pratheek
Message 5 of 12
(4,491 Views)
Accepted by pratheek
See attached:
Message 6 of 12
(4,487 Views)
Thanks alot.....
Message 7 of 12
(4,483 Views)
Hi Phil_
I have a problem.....The items in my 1st combobox contains the data as in the attachment below. it is a .csv file....... in the 2nd combobox i need only o/p-1 and o/p-2 to be shown......... So in the case structure, i need to read the .csv file, compare the data and then wire it to the string[]. Is this the correct procedure ? if not could you please tell me how could i do it
Pratheek
Message 8 of 12
(4,465 Views)
That sounds reasonable to me.
Try it out and see if it works! If it dosen't post your code so we can help.
The 'read from spreadsheet' VI in the file I/O section of the Programming pallette, would be useful to read your .csv.
Message 9 of 12
(4,455 Views)
Thanks alot........ i'll get back to you soon....
Message 10 of 12
(4,446 Views)
