color recognition in Labview
Hello all,
I'm a beginner at
machine vision using Labview , I need your help please
I did not know what kind of matrix color spectrum and how we chose values 1.1, 0.9 ..etc ??? as shown in the picture
(4,868 Views)
Hello and Welcome!
Did you get started with the Color Matching.vi example?  It uses that function and breaks down how it interprets the arrays it produces.
I would start there and go to Help>>Find Examples>>Color Matching and run that so you can see how the code is used and what it produces.
If you do have some follow up questions I would post the code you are having some trouble with.
-Bear
Ben Johnson
ʕง•ᴥ•ʔง
(4,805 Views)
Thank you very much .. I saw it was very complicated .. I will understand it well
(4,798 Views)
Usually color detection works better in another color space then RGB, e.g. HSL. I never used the spectrum VI you're showing, it seems a bit too complicated for most tasks.
If you explain a bit more about your problem, we'd be able to help you better.
If the previous post solved your problem, accept is a s a solution. Or we'll keep bothering you with solutions until you do Smiley Very Happy.
(4,793 Views)
