code calls Word, exe doesn't
ok, the error that is returned for the exe is: Error 7 occurred at Get LV Class Default Value.vi, and the call chain is: Get LV Class Default Value.vi > NI_reportlvclass: New Report.vi
in my project explorer, I found this under Dependencies > vi.lib >
does this need to be elsewhere in the project or explicitly included somehow?
Lawrence M. David Jr.
Certified LabVIEW Architect
cell: 516.819.9711
http://www.aleconsultants.com
larry@aleconsultants.com
Message 11 of 19
(2,278 Views)
Accepted by topic author lmd2
Can you remove the _Word Dynamic VIs.vi and _Excel Dynamic VIs.vi from your project, and instead include NI_Word.lvclass and NI_Excel.lvclass in your project, and specify those .lvclasses as "Always Included" in your build?  Let me know if that helps.
Message 12 of 19
(2,264 Views)
thank you sir, that was the fix
cell: 516.819.9711
Message 13 of 19
(2,259 Views)
 Dear Lawrence M. David Jr.
    I meet the same problems as you mentioned:That is, the program can read data from excel in code,but it generate error in exe.My LabVIEW version is also 8.6. I read messages in the NI forum,but I can not resove it.So Please tell me how to do exe.
Thank you
Sincerely yours,
Wang Ligang
Message 14 of 19
(2,188 Views)
Here is the attachment
Message 15 of 19
(2,186 Views)
The problem is that when you're running as an EXE, you're adding a 'data' folder to the path to the excel file that you're passing to the Report Gen VIs.  This is happening in your AutoSelPath.vi.  Since you're getting the path from a file dialog, you should just use the value you get from the dialog directly, as opposed to trying to manipulate it in your code.
Message 16 of 19
(2,182 Views)
Thank you . I modiy the problem in AutoSelPath,but I can not run in exe.How can I config it in the project files?
Thank you
The attachment is new Program.
Message 17 of 19
(2,176 Views)
Did you add NI_Excel.lvclass to the project, and then include it in your EXE build as an "Always Included" file?  As has been mentioned in previous threads, you must do this to get your built EXE to run correctly.
Message 18 of 19
(2,172 Views)
thank you.I got it.
Message 19 of 19
(2,165 Views)
