cluster/ visibility help
Hello all,
        I have a regarding clusters and visibility of numeric controls inside the cluster. Attached you will find a code I'm working with where the numeric controls left1 thru 4 and right 1 thru right 4 are displayed inside the cluster and will index the column with the increment of y value. The question I have is if to display only values > 0.
left      right
1          2
0          1
1          0
0          3
to look like
left    right
1        2
          1
1
           3
Please provide me your inputs.
thanks.
K
(2,569 Views)
Have you tried to setup the condition if value=0, with a case structure, for a property node of the indicators?  You can select the property that you wish to set accordingly.
Yik
(2,550 Views)
